- Acer ET430Kwmiippx - LED monitor - 4K - 43"
- LED-backlit LCD monitor - 43"
- Energy Class
- Class A
- Energy Consumption per Year
- 100 kWh
- Power Consumption (On mode)
- 55 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort
- Tilt
- Voltage
- AC 120/230 V
- Black
- 96.59 cm x 24.28 cm x 65.33 cm
- MPR II, TUV GS, ISO9241-307
- Display Type
- Energy Class
- Class A
- 100 kWh
- Diagonal Size
- 43"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
- Black
- 96.59 cm x 24.28 cm x 65.33 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -3.5/+11.5
- VESA Mounting Interface
- 200 x 100 mm
- MTBF
- 30,000 hour(s)
- Input Voltage
- AC 120/230 V
- 55 W
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Sleep
- 0.45 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 96.59 cm - depth: 6.53 cm - height: 56.15 cm , With stand - width: 96.59 cm - depth: 24.28 cm - height: 65.33 cm
