Acer ET430K 43" 3840x2160 5ms HDMI DP Mini DP LED Monitor
Quicklinx: DB0BWS00 Mfr#: UM.ME0EE.010
Diagonal Size: 43in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort
14 in stock
£423.00 ex VAT
£507.60 inc VAT
Acer ET430K - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class A
Energy Consumption per Year
100 kWh
Power Consumption (On mode)
69 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
White
96.6 cm x 24.3 cm x 65.3 cm
12.36 kg
MPR II
Display Type
Energy Class
Class A
100 kWh
69 W
Diagonal Size
43"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
72% NTSC colour gamut, ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
White
12.36 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+11.5
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable
MPR II
AC 120/230 V
55 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
5 °C
35 °C
10 - 85% (non-condensing)
Acer ET430K 43 Bundle deal on Acer ET430K 43" 3840x2160 5ms HDMI DP Mini DP LED Monitor
£522.17
Diagonal Size: 43in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Acer
Price Range Ex VAT: 300 - 500
