Acer ET322QK 31.5" 3840x2160 4ms HDMI DP VGA LED Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: DPQFWS00 Mfr#: UM.JE2EE.013
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£411.23 ex VAT
£493.47 inc VAT
A stylishly curved Full HD display not only looks good but increases user visibility. A combination of technologies is used to provide users with a great viewing experience. Crisp, true-to-life colors come alive in Full HD 1080p resolution.
  • Elegant and Functional Design
    A stylishly curved Full-HD display not only looks good but increases user visibility.
  • Delivering Great Imaging Technology
  • Full HD Resolution
    Crisp, true-to-life colours come alive in Full HD 1080p resolution.
  • ZeroFrame
    Improved enjoyment and maximum visibility of the screen with the frameless design.
  • Stand Strong
    Two thin, strong metal feet grace the bottom of the ET2, holding the impressive 31.5" screen aloft for all to admire.
  • Care for Your Vision
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
  • Professional Color Adjustment
    For professional editing, achieve true-life accuracy with 6-Axis Color Adjustment.
  • Wide Angle Display
    Share what's on your screen with friends and family as colors stay true no matter what angle you're viewing from.
Acer ET322QK - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
43 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White
73 cm x 24.7 cm x 52.9 cm
5.62 kg
Russia
MPR II, Directive 1275/2008, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 55032:2012+AC:2013 Class B, EN 6100-3-3:2013, EN 61000-3-2:2014 Class D, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Display Type
Energy Class
Class B
63 kWh
43 W
Diagonal Size
31.5"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView
White
73 cm x 24.7 cm x 52.9 cm - without stand
5.62 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
2 x HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+11.5
VESA interface support
1 x DisplayPort cable
Russia
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.34 Watt
Acer ET322QK 31.5 Bundle deal on Acer ET322QK 31.5" 3840x2160 4ms HDMI DP VGA LED Monitor
£510.40
Response Time: 4ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 300 - 500
