Everything you need from a standard sized desktop in a fraction of the space. Maintain productivity with powerful features that keep your business running smoothly.
Powerful performance
Heavy-duty performance for all the programs you need to work. No lag nor freezing of large spreadsheets, multiple presentations or when editing large graphics. With an advanced processor and a powerful graphics card. -
Faster file access
Smoothly and quickly view and edit large spreadsheets, presentations and video. With higher performance and lower power, DDR4 memory and the SATA SSD give accelerated access to files and the operating system. -
Ports for all occasions
Expand the functionality with a host of ports to connect almost any secondary device. The USB ports front and back, a legacy VGA port, a modern HDMI port and a Gigabit LAN Ethernet port allow it to operate in many office environments. -
Faster wireless speeds
In wireless offices it's important to have PCs capable of fast Wi-Fi access. The integrated wireless module provides slicker streaming.
- Acer Veriton Essential ES2 VES2710G - MT - Core i5 7400 3 GHz - 4 GB - HDD 1 TB
- Personal computer - mini tower
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (7th Gen) 7400 / 3 GHz (3.5 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 630
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Windows 10 Pro 64-bit Edition
- 16.5 cm x 32 cm x 34 cm
- 8 kg
- Personal computer
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Manufacturer
- Seagate
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111H
- Data Link Protocol
- Bays
- 5.25" , 3.5"
- Slots
- 1 PCIe x16
- 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, EuP
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 220 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 16.5 cm
- 32 cm
- 34 cm
- 8 kg
