Acer Essential ES2710 i3-7100 4GB 1TB Win 10 Pro 64 bit
UP TO A POSSIBLE £100 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: D9Z6WS00 Mfr#: DT.VQEEK.001
  • Core i3
  • Powerful performance
    Heavy-duty performance for all the programs you need to work. No lag nor freezing of large spreadsheets, multiple presentations or when editing large graphics. With an advanced processor and a powerful graphics card.
  • Faster file access
    Smoothly and quickly view and edit large spreadsheets, presentations and video. With higher performance and lower power, DDR4 memory and the SATA SSD give accelerated access to files and the operating system.
  • Ports for all occasions
    Expand the functionality with a host of ports to connect almost any secondary device. The USB ports front and back, a legacy VGA port, a modern HDMI port and a Gigabit LAN Ethernet port allow it to operate in many office environments.
  • Faster wireless speeds
    In wireless offices it's important to have PCs capable of fast Wi-Fi access. The integrated wireless module provides slicker streaming.
Acer Veriton Essential ES2 VES2710G - MT - Core i3 7100 3.9 GHz - 4 GB - 1 TB
Personal computer - mini tower
Region: United Kingdom
1 x Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
GigE
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
16.5 cm x 32 cm x 34 cm
8 kg
Personal computer
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111H
Bays
5.25" , 3.5"
Slots
1 (total) / 0 (free) x CPU , DIMM 288-pin , 2 PCIe x1 , 1 PCIe x16 , 1 PCI
4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x serial , 1 x DVI , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EuP
Power supply
Nominal Voltage
AC 120/230 V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
16.5 cm
32 cm
34 cm
8 kg
