Acer ED322QAwmidx 31.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: G0GHWS00 Mfr#: UM.JE2EE.A04
Acer ED322Q Awmidx - LED monitor - curved - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
71.1 cm x 20.8 cm x 52.6 cm
5.86 kg
MPR II
Display Type
Energy Class
Class A
45 kWh
Diagonal Size
31.5"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Acer BluelightShield technology
White
71.1 cm x 20.8 cm x 52.6 cm - with stand
5.86 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+10
1 x VGA cable
MPR II
Input Voltage
31 W
Power Consumption (Typical)
42 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 71.1 cm - depth: 20.8 cm - height: 52.6 cm - weight: 5.86 kg , Without stand - width: 71.1 cm - depth: 7.95 cm - height: 41.5 cm
