Immerse yourself in the graphics of work or play on this Acer curved monitor. The edge-to-edge frameless screen is a full 31.5 inches, wrapping you within the action of your favorite games and streaming movies. EyeProtect Flicker-Less and BlueLightShield technology on this Acer curved monitor defend your eyes from strain.
Curved immersion
The Acer ED322Q curved display with high resolution offers sharp picture quality and provides a perfect picture with a broader view. This monitor presents stunning, lifelike images with an amazing level of detail that makes games more exciting and movies truly cinematic. The curved screen panel and frameless screen wraps you in a world of entertainment with every corner of the screen at the same distance from your eyes for a uniform viewing experience without blind spots. The Acer ED322Q curved monitor was designed with dynamic angles for gaming, work or leisure. The solid stand with futuristic aluminium base is unique and the cable management helps to organise power, keyboard, mouse and accessory cables easily. -
Entertainment
Rapid response time reduces deviations in transition time to deliver high-quality moving images bringing immersive graphics to your movies and games. Stay in your game for hours with Flicker-less technology. Give your neck a break too, the ergonomic stand lets you find your comfortable view with tilts from -5° to 15°. -
Ports
With VGA, DVI & HDMI inputs you can easily power and extend the enjoyment from your smartphone or tablet on display.
- Acer ED322Q - LED monitor - curved - Full HD (1080p) - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 32 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.36375 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- Dimensions (WxDxH) - without stand
- 71.1 cm x 20.8 cm x 52.6 cm
- 5.86 kg
- FCC Class B certified, MPR II, UL, TUV, VCCI, cUL, GS, NOM, RoHS, WEEE, EAC
- Display Type
- Energy Class
- Class F
- 62 kWh
- Diagonal Size
- 31.5"
- Curved Screen
- Yes (1800R)
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.36375 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Acer BluelightShield technology
- White
- 71.1 cm x 20.8 cm x 52.6 cm - without stand
- 5.86 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- VGA , DVI , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- Input Voltage
- 32 W
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption (Typical)
- 35 Watt
- 1 Watt
- On / Off Switch
- No
