Acer ED322Q 31.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: CXFLWS00 Mfr#: UM.JE2EE.009
Diagonal Size: 31.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
Select:
£228.47 ex VAT
£274.16 inc VAT
Immerse yourself in the graphics of work or play on this Acer curved monitor. The edge-to-edge frameless screen is a full 31.5 inches, wrapping you within the action of your favorite games and streaming movies. EyeProtect Flicker-Less and BlueLightShield technology on this Acer curved monitor defend your eyes from strain.
  • Curved immersion
    The Acer ED322Q curved display with high resolution offers sharp picture quality and provides a perfect picture with a broader view. This monitor presents stunning, lifelike images with an amazing level of detail that makes games more exciting and movies truly cinematic. The curved screen panel and frameless screen wraps you in a world of entertainment with every corner of the screen at the same distance from your eyes for a uniform viewing experience without blind spots. The Acer ED322Q curved monitor was designed with dynamic angles for gaming, work or leisure. The solid stand with futuristic aluminum base is unique and the cable management helps to organize power, keyboard, mouse and accessory cables easily.
  • Entertainment
    Rapid response time reduces deviations in transition time to deliver high-quality moving images bringing immersive graphics to your movies and games. Stay in your game for hours with Flicker-less technology. Give your neck a break too, the ergonomic stand lets you find your comfortable view with tilts from -5° to 15°.
  • Ports
    With VGA, DVI & HDMI inputs you can easily power and extend the enjoyment from your smartphone or tablet on display.
Acer ED322Q - LED monitor - curved - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White
71.1 cm x 20.8 cm x 52.6 cm
5.86 kg
FCC Class B certified, MPR II, UL, TUV, VCCI, cUL, GS, NOM, RoHS, WEEE, EAC
Display Type
Energy Class
Class B
62 kWh
42 W
Diagonal Size
31.5"
Curved Screen
Yes (1800R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Acer BluelightShield technology
White
71.1 cm x 20.8 cm x 52.6 cm - without stand
5.86 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
35 Watt
Power Consumption (Off Mode)
1 Watt
On / Off Switch
No
Acer ED322Q 31.5 Bundle deal on Acer ED322Q 31.5" 1920x1080 4ms VGA DVI HDMI LED Monitor
£327.64
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
