Acer ED273 27" 1920x1080 4ms DVI HDMI MM Curved Monitor
Quicklinx: DB05WS00 Mfr#: UM.HE3EE.005
Select:
  • 27"
Immerse yourself in the graphics of work or play on this Acer curved monitor. The edge-to-edge frameless screen is a full 31.5 inches, wrapping you within the action of your favorite games and streaming movies. EyeProtect Flicker-Less and BlueLightShield technology on this Acer curved monitor defend your eyes from strain.
  • Curved 16:9
    Acer ED3 monitor gives you a more enveloping viewing experience because their screens wrap around you, thus drawing you deeper into everything.
  • Flicker-less
    Acer Flicker-less technology helps to eliminate screen flickering through a stable supply of power.
  • BlueLightShield
    Acer BlueLightShield reduces the exposure ratio of blue light, which can potentially cause long-term eye damage, by adjusting color hue and brightness.
Acer ED273wmidx - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Curved Screen
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
61.28 cm x 16.82 cm x 46.59 cm
Display Type
Energy Class
Class F
40 kWh
Diagonal Size
27"
Curved Screen
Yes (1800R)
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Matte, High Frame Rate Control (Hi-FRC), ComfyView, Flicker-Less technology, Wide Viewing Angle, Acer BluelightShield technology
61.28 cm x 16.82 cm x 46.59 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
27 W
26 kWh/1000h
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.28 cm - depth: 16.82 cm - height: 46.59 cm , Without stand - width: 61.28 cm - depth: 7.54 cm - height: 36.19 cm
