Acer ED242Q 23.6" 1920 x 1080 4ms HDMI VGA LCD Monitor
Quicklinx: DG72WS00 Mfr#: UM.UE2EE.001
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£135.41 ex VAT
£162.49 inc VAT
BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand. Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
  • Ultra-low blue light technology
  • Flickerless technology
  • ComfyView display
    ComfyView technology reduces the amount of light being reflected on your display for more comfortable viewing in various settings.
  • Wide viewing angle
    Wide viewing angle signage is able to be viewed from 178° and still preserve image clarity and prime colors.
Acer ED242QRwi - LED monitor - curved - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.27156 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
White
Display Type
Energy Class
Class B
40 kWh
27 W
Diagonal Size
23.6"
Curved Screen
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27156 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, 84% colour gamut, Flicker-Less technology, Wide Viewing Angle, Acer BluelightShield technology, Ultra Low Blue Light technology, Ultra-Low Blue Light Technology
White
HDMI ¦ VGA
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Acer ED242Q 23.6 Bundle deal on Acer ED242Q 23.6" 1920 x 1080 4ms HDMI VGA LCD Monitor
£234.58
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
