Acer EB550K 55" 3840 x 2160 4ms HDMI LED Monitor
Quicklinx: F2R9WS00 Mfr#: UM.NE0EE.001
Diagonal Size: 55in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
15 in stock
£812.51 ex VAT
£975.01 inc VAT
Acer EB550K - LED monitor - 4K - 55"
LED-backlit LCD monitor - 55"
Energy Class
Class A
Energy Consumption per Year
126 kWh
Power Consumption (On mode)
86 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
3xHDMI, VGA, DisplayPort
124.16 cm x 23.74 cm x 77.97 cm
14.4 kg
Ukraine, Romania, Croatia
MPR II, FCC, RoHS
Display Type
Energy Class
Class A
126 kWh
86 W
Diagonal Size
55"
Viewable Size
54.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 76 Hz
Horizontal Refresh Rate
15 - 136 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 10-bit gamma, 72% NTSC colour gamut, ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, HDR Ready technology, Picture-in-Picture, Picture-by-Picture
124.16 cm x 23.74 cm x 77.97 cm - with stand
14.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
3 x HDMI , VGA , DisplayPort , Audio line-out
Mechanical
VESA Mounting Interface
400 x 200 mm
VESA interface support
1 x VGA cable , 1 x DisplayPort cable
MPR II, FCC, RoHS
130 Watt
Power Consumption Stand by
500 mW
Power Consumption (Off Mode)
500 mW
Dimensions & Weight Details
With stand - width: 124.16 cm - depth: 23.74 cm - height: 77.97 cm - weight: 14.4 kg , Without stand - width: 124.16 cm - depth: 6.99 cm - height: 72.12 cm - weight: 14 kg
Acer EB550K 55 Bundle deal on Acer EB550K 55" 3840 x 2160 4ms HDMI LED Monitor
£911.68
Diagonal Size: 55in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 750 - 1000
