Acer EB490QK 48.5" 3840x2160 4ms VGA HDMI Display Port LED Monito
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: DPP8WS00 Mfr#: UM.SE0EE.001
Diagonal Size: 48.5in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£542.94 ex VAT
£651.52 inc VAT
  • Enjoy the view
    Color-enhancing, image-sharpening and eyecare technologies combine flawlessly in vibrant resolution.
  • Speakers at the ready
    Two speakers, directly built in to your monitor, save on desk space while still offering up a powerful listening experience.
  • Reach incredible depths of color
    A wider color range results in less banding, creating a smoother, more realistic image.
  • Get a good look
    Super sharpness takes low-resolution images and bumps them up a notch, giving what you see that Ultra HD feel.
Acer EB490QK - LED monitor - 4K - 48.5"
LED-backlit LCD monitor - 48.5"
Energy Class
Class A+
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.27963 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
3xHDMI, VGA, DisplayPort
Screen Coating
Semi-glare
110.85 cm x 8.1 cm x 64.13 cm
11.7 kg
MPR II, VCCI, NEMKO, CCC, FCC, DDC/CI, RoHS, ISO 9241-307, EAC, NOM-NYCE
Display Type
Energy Class
Class A+
82 kWh
56 W
Diagonal Size
48.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27963 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Semi-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 10-bit gamma, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, 6-Axis Color Adjustments, Picture-in-Picture
110.85 cm x 8.1 cm x 64.13 cm - without stand
11.7 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
3 x HDMI , VGA , DisplayPort , Audio line-out
Mechanical
VESA Mounting Interface
400 x 200 mm
VESA interface support
1 x VGA cable , 1 x DisplayPort cable
130 Watt
Power Consumption Stand by
450 mW
Power Consumption (Off Mode)
400 mW
Dimensions & Weight Details
With stand - weight: 12.1 kg
10 - 90%
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 500 - 750
