Acer CXI3 R62V01 CM3865U 4GB 32GB SSD Chrome OS
Quicklinx: F3JHWS00 Mfr#: DT.Z11EK.001
  • Celeron
  • IEEE 802.11n
  • Easier
    Play and work from the get-go with your favorite apps. When you need to access an application or file on another system, you can do that.
  • Faster
    It starts fast, so you can wait less and do more. The Acer Chromebox sports a dual antenna design that provides a quicker, more reliable wireless connection for an overall smoother Internet experience. And, you can access your media on external drives super-fast via the USB 3.0 port.
  • More secure
    The Acer Chromebox has virus protection built-in, so it stays healthy while providing you with peace of mind. Equipped with TPM 1.2, the Acer Chromebox meets stringent security standards to ensure the integrity of your data. What's more, a Kensington lock slot protects this Chromebox from theft.
  • More manageable
    The Acer Chromebox uses a web-based management console that makes it easy to deploy as well as control users, devices and apps remotely. You won't be bothered by updates, as they're done automatically.
Acer Chromebox CXI3 - mini PC - Celeron 3867U 1.8 GHz - 4 GB - SSD 32 GB
Chromebox - mini PC
Region: United Kingdom
1 x Intel Celeron 3867U / 1.8 GHz (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Hard Drive
SSD 32 GB
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics 610
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Google Chrome OS
14.85 cm x 15.1 cm x 4 cm
660 g
Chromebox
Product Form Factor
Mini PC
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 32 GB
Manufacturer
Kingston
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Interface (Bus) Type
M.2 2230
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
5 x USB 3.1 Gen 1 (2 front, 3 rear) , 1 x USB-C 3.1 Gen 1 , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front)
VESA mounting kit, 2x wireless aerials
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Google Chrome OS
14.85 cm
15.1 cm
4 cm
660 g
