Acer Curved 1900R 21:9 UltraWide QHD 34' IPS LED 100M:1 ACM 300ni
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: C7BKWS00 Mfr#: UM.CX2EE.001
  • Curved immersion
    Plenty of curved screen real estate and a cinematic 21:9 aspect ratio make sure games and movies look as epic as possible.
  • Perfect picture
    This monitor sports a curved UltraWide QHD display with ColorPlus technology, featuring sRGB gamut and 6-axis color adjustment for a perfect picture.
  • No screen tearing
    Say "goodbye" to stuttering and tearing. FreeSync and Adaptive-Sync technologies match the refresh rate of your monitor with your graphics card to provide the smooth gaming experience.
  • Epic audio
    Get into games with built-in DTS Sound speakers. World-class audio is coming to your movies, games and music.
  • Custom multitasking
    Picture-in-Picture and Picture-by-Picture display modes let you fully customize your display. Drive the XR series along with other monitors in a daisy-chain configuration, using only one video output.
  • Luxury design
    Achieve ultimate gaming luxury with dynamic angles, cool ambient lighting, and a futuristic aluminum base. Your desk has never looked this good.
  • Reduce fatigue
    Stay in the fight for hours with EyeProtect's Flicker-less and Blue-light Filtering technology. Give your neck a break too, with very flexible tilt and height adjustments.
  • All set - HDR ready
    HDR is a display technology, that creates deeper levels of black and white contrast, giving you a greater level immersion through realistic image recreation. Using scalar chip decoding and mapping technology, the Edge-lit LED panel and global dimming functionality, the XR series display pulls you in to the lifelike contrast and color of HDR.
Acer XR342CK - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
78 kWh
Power Consumption (On mode)
53 W
Curved Screen
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (MPRT)
Colour Support
1.07 billion colours
Input Connectors
HDMI, HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, tilt
81.62 cm x 30.9 cm x 56.55 cm
9.7 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
78 kWh
53 W
Diagonal Size
34"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (MPRT)
Backlight Technology
LED backlight
100% sRGB colour gamut, daisy chain compatible, 6-axis colour adjustment, DTS Sound, Adaptive-Sync technology, adjustable ambient lighting
81.62 cm x 30.9 cm x 56.55 cm - with stand
9.7 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , MHL / HDMI , DisplayPort , DisplayPort output , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out , USB-C
Mechanical
Height, tilt
Tilt Angle
-5/+35
Height Adjustment
130 mm
Flicker-free technology
1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x HDMI cable
Power Consumption Stand by
500 mW
Power Consumption Sleep
480 mW
Dimensions & Weight Details
With stand - width: 81.62 cm - depth: 30.9 cm - height: 56.55 cm - weight: 9.7 kg , Without stand - width: 81.62 cm - depth: 12.47 cm - height: 36.77 cm - weight: 6.55 kg
ENERGY STAR Certified
