Acer CP713-2W i3-10110U 8GB 128GB 13.5" Chrome OS
Quicklinx: FYG8WS00 Mfr#: NX.HQBEK.001
More than 50 in stock
£540.72 ex VAT
£648.86 inc VAT
Crisp, clear, perfect, visuals are displayed on the high-resolution screen with a 178° viewing angle. With a high-resolution display, movies and TV shows are shown in great clarity, and then share the screen with those around you with the expansive viewing angle.
  • Sharp images
  • Write naturally
    Write with greater control and precision. The elastomer tip of the pen provides a more natural writing experience. Take advantage of the higher friction and elasticity to reduce sliding across the smooth surface of the screen.
  • Stylish yet tough
    Strength, durability and stylish good looks are provided through the aluminum chassis. The lightweight material means that it is less likely to be bent, warped or dented than other materials.
  • Tougher glass
    Tougher glass provides greater scratch resistance for the display, and for the touchpad it provides a slicker smoother feel than regular plastic.
Acer Chromebook Spin 713 CP713-2W-36LN - 13.5" - Core i3 10110U - 8 GB RAM - 128 GB SSD - UK
Chromebook - flip design
Operating System
Chrome OS
Intel Core i3 (10th Gen) 10110U / 2.1 GHz (4.1 GHz) / 4 MB Cache
8 GB DDR4 (8 GB (soldered))
Storage
128 GB SSD
Display
13.5" LED backlight touchscreen 2256 x 1504
Graphics
Intel UHD Graphics
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
3-cell - up to 10 hours
Accelerometer, gyro sensor
Steel grey
30.065 cm x 23.5 cm x 1.68 cm
1.37 kg
Region: United Kingdom
Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
RAM
8 GB (8 GB (soldered))
DDR4 SDRAM
SO-DIMM 260-pin
Storage
Main Storage
128 GB SSD - SanDisk
Display
13.5" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
2256 x 1504
Widescreen
Image Aspect Ratio
3:2
Image Brightness
415 cd/m²
Bezel Type
Flat front
Corning Gorilla glass, glare, CineCrystal, 30 ms response rate
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Video Resolutions
1280 x 720
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 Card
3-cell Lithium Ion
48 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
USB 3.0 , 2 x USB-C 3.1/DisplayPort , Headphone/microphone combo jack , HDMI
Steel grey
Integrated Options
HDCP Compliant
USB-C power adapter
MIL-STD 810G
Localization
1.37 kg
Brand: Acer
Price Range Ex VAT: 500 - 750
