Crisp, clear, perfect, visuals are displayed on the high-resolution screen with a 178° viewing angle. With a high-resolution display, movies and TV shows are shown in great clarity, and then share the screen with those around you with the expansive viewing angle.
Sharp images
With a high-resolution display, movies and TV shows are shown in great clarity, and then share the screen with those around you with the expansive viewing angle. -
Write naturally
Write with greater control and precision. The elastomer tip of the pen provides a more natural writing experience. Take advantage of the higher friction and elasticity to reduce sliding across the smooth surface of the screen. -
Stylish yet tough
Strength, durability and stylish good looks are provided through the aluminum chassis. The lightweight material means that it is less likely to be bent, warped or dented than other materials. -
Tougher glass
Tougher glass provides greater scratch resistance for the display, and for the touchpad it provides a slicker smoother feel than regular plastic.
- Acer Chromebook Spin 713 CP713-2W-36LN - 13.5" - Core i3 10110U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Core i3 (10th Gen) 10110U / 2.1 GHz (4.1 GHz) / 4 MB Cache
- Memory
- 8 GB DDR4 (8 GB (soldered))
- Storage
- 128 GB SSD
- Display
- 13.5" LED backlight touchscreen 2256 x 1504
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
- Battery
- 3-cell - up to 10 hours
- Accelerometer, gyro sensor
- Steel grey
- 30.065 cm x 23.5 cm x 1.68 cm
- 1.37 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (8 GB (soldered))
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
Storage
- Main Storage
- 128 GB SSD - SanDisk
Display
- 13.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2256 x 1504
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 415 cd/m²
- Bezel Type
- Flat front
- Corning Gorilla glass, glare, CineCrystal, 30 ms response rate
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 Card
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- USB 3.0 , 2 x USB-C 3.1/DisplayPort , Headphone/microphone combo jack , HDMI
- Steel grey
- Integrated Options
- HDCP Compliant
- Included Accessories
- USB-C power adapter
- MIL-STD 810G
- Localization
- 1.37 kg
