Acer Concept D 500 Intel Core i7-9700K 32GB 1TB HDD+1TB Win10P
Quicklinx: G551WS00 Mfr#: DT.C03EK.00C
  • Core i7
  • IEEE 802.11n
The attractive and stylish ConceptD 500 delivers reliable computing performance for complex creative projects helping creators build amazing art in real time.
  • ConceptD 500
    THE IDEAL DESKTOP FOR CREATIVES
  • Optimal Performance Workstation
    Equipped to handle heavy workloads, the ConceptD 500 is powered by the latest 9th Generation Intel Core i9 processor with 5GHz, 8 cores and 16 threads, making sure applications and projects runs faster, smoother and with more stability.
  • Create Without Boundaries
    As designs become more complex, visual effects grow in size, complexity, and scope. NVIDIA Quadro RTX 4000 graphics cards provide unmatched power for unmatched creative freedom in areas like photorealistic 3D animation, AI-powered workflows and ultra-quality video. Enjoy greater fluidity with photorealistic ray-tracing; experience faster performance with AI-enabled applications and create detailed, lifelike VR experiences more cost-effectively and across a broader range of workstation chassis configurations.
  • Amazing Performance
    NVIDIA Turing architecture combined with NVIDIA RTX technology brings real-time ray-tracing to professional workstation users.
  • Advanced Display Features
    Experience stunning image quality with the power to drive up to four 8K displays with HDR support via Display Port 1.4. HDR supports twice the visible colors for brighter, more saturated images.
  • Immersive VR
    The Quadro RTX 4000 is specially designed with the performance that is necessary to drive immersive VR environments, enabling the most detailed, life-like VR experience possible.
  • Optimized Quiet Cooling
    Processor intensive applications such as rendering and video production will cause the processor and GPU to run hot, therefore it's essential that the cooling is the best it can be. The ConceptD 500 has optimal thermal, ventilation, airflow dynamics and is cooled using three cooling fans to draw the air in through the triangular front air panel and circulating it throughout the chassis. And yet, at just 40dB it is still quiet enough to be unobtrusive.
  • Independent Software Vendors (ISV)
    To meet the demands of engineers, architects, videographers, cinematographers, 3D animators, AI professionals and many more, a hardware solution that has been tested and certified by Independent Software Vendors (ISVs) is demanded. ConceptD products, in specific model configurations, offer ISV certified hardware in combination with the most recent technologies.
  • Elegantly Honest
    Designed to fit into any modern studio the ConceptD 500 has a round cornered white minimalist design with a wood effect top and triangular front panel. Beyond the simple aesthetic is an array of thoughtful and practical functions e.g. convenient wireless charging and an array of high speed connecting ports. At the front is an integrated amber light which gives a sense of warmth.
  • Wireless Charging
    Fast charge your modern Qi-compatible devices without the need to plug your device into a wall
  • Headset Cradle
    The thoughtfully designed push pop-out design gives freedom to use and tuck it away when not in use.
  • Cable Management
    Maintain clean and neat look from behind, sort messy cables.
  • Impressive Expandability
    Expandable workstation designed to grow with you to meet your ever-changing workload requirements. Quickly access and store massive amounts of data and files with flexible storages options.
  • Quicker Response
    Work with large models and render complex 3D models in real time with bigger, faster storage options include onboard PCIe M.2 SSD.
  • Ultrafast PCIe Interface
    4 x DIMM 2666 Mhz DDR4 memory up to 64GB has more bandwidth and capacity. Experience fast performance when working on complex design tasks.
  • Tool-less HDD Drive
    Quickly access and store massive amounts of data and files with two storage bays supporting both 2.5" and 3.5" HDDs.
  • Secure and Manageable Workstation
    The ConceptD 500 has a host of features designed to keep your data and machine safe from failure.
  • Health Indicator Light
    For quick trouble-shooting, the health indicator displays warning indications via the power button and amber LED light.
  • Intrusion Alarm
    The system comes with an intrusion alarm to prevent theft and unauthorized access.
  • ConceptD Palette
    Quickly and easily monitor your system CPU, GPU, and memory usage through the intuitive ConceptD Palette.
Acer ConceptD 500 CT500-51A - mid tower - AI Ready - Core i7 9700K 3.6 GHz - 32 GB - SSD 1.024 TB, HDD 1 TB
Workstation - mid tower AI Ready
Region: United Kingdom
1 x Intel Core i7 (9th Gen) 9700K / 3.6 GHz (, up to 4.9 GHz, (8-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
32 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 1.024 TB - Self-Encrypting Drive
Hard Drive (2nd)
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Card Reader
Graphics Controller
PCIe x16 - NVIDIA Quadro P4000
Video Memory
8 GB GDDR5 SDRAM
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
20.4 cm x 47.6 cm x 43.9 cm
9 kg
Limited warranty - 3 years - carry-in
Workstation - AI Ready
Product Form Factor
Mid tower
Built-in Devices
Wireless charger, headset stand, amber LED lighting
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Max Turbo Speed
4.9 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Unbuffered, dual channel memory architecture
Configuration Features
2 x 16 GB
Hard Drive
SSD
1 x 1.024 TB
Manufacturer
Samsung
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Manufacturer
Seagate
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe x16
Graphics Processor
NVIDIA Quadro P4000
Video Memory
8 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Ethernet Controller
Realtek RTL8111EPV
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Wake on LAN (WoL)
Slots
2 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI , 2 M.2 Card
3 x USB 3.1 Gen 2 (2 rear, 1 top) , 4 x USB 2.0 (2 top, 2 rear) , 1 x headphones/microphone (1 top) , 2 x microphone (1 top, 1 rear) , 1 x USB-C 3.1 Gen 2 (1 top) , 4 x DisplayPort , 2 x USB 3.1 Gen 1 , 1 x audio line-out/headphones , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard / mouse
2x wireless aerials, thermal pad
BSMI, CB, RoHS, PC 2001
Power supply
AC 120/230 V
Power Provided
500 Watt
Efficiency
87%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
20.4 cm
47.6 cm
43.9 cm
9 kg
G551 APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt In Stock £447.21
G551 APC BACK UPS PRO BR900MI 900VA 6 Outlets In Stock £208.36
G551 APC BACK UPS PRO BR1300MI 1300VA 8 Outlets In Stock £299.20
G551 APC BACK UPS PRO BR1600MI 1600VA 8 Outlets In Stock £367.34
