Acer Chromebox CXI3 is designed for business in multiple environments whether in offices or digital signage. Get superb security and versatile connectivity for all manner of businesses.
Polished performance
Chrome OS's streamlined delivery gives fast operation, enhanced security and intuitive use. -
Smarter control
The web-based Google management console makes it easy to deploy and control users, devices and apps across a fleet of Chrome devices. -
Always secure and up to date
Automatic updates keep your data as secure as can be with multiple levels of security. -
Ultra-quick data transfer
Ultra-quick data transfer, video streaming, and battery charging with USB 3.1 Gen 1 Type C. -
Double work efficiency
Expand your viewing area and maximize productivity as you extend your desktop across two monitors.
- Acer Chromebox CXI3 - mini PC - Core i5 8250U 1.6 GHz - 8 GB - SSD 64 GB
- Chromebox - mini PC
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 64 GB - M.2
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel UHD Graphics 620
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
- OS Provided
- Google Chrome OS
- Black
- 15.1 cm x 14.85 cm x 4 cm
- 2 kg
- Chromebox
- Product Form Factor
- Mini PC
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 64 GB
- Manufacturer
- Kingston
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Interface (Bus) Type
- M.2 Card
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- 5 x USB 3.1 Gen 1 (2 front, 3 rear) , 1 x USB-C 3.1 Gen 1 , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front)
- Included Accessories
- VESA mounting kit, 2x wireless aerials
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
- Google Chrome OS
- 15.1 cm
- 14.85 cm
- 4 cm
- 2 kg
