Acer Chromebook Intel Celeron N2840 4GB 32GB 11.6" Chrome OS
Quicklinx: 9T16WS00 Mfr#: NX.MRCEK.003
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
Thin, light and equipped with an array of premium features, the Acer Chromebook 11 combines power and practicality - as well as value for money.
Acer's 11.6-inch Chromebook provides a number of improvements on its predecessor. Its design is tougher and more robust, with a thicker cover, reinforced corners, longer hinge brackets and additional rib panels. Its spill-resistant keyboard is also complemented by a liquid drainage system to provide protection against accidents.
Powered by a 2.16GHz dual-core Intel Celeron processor, the Acer Chromebook 11 also comes equipped with 4GB RAM and a 32GB SSD hard drive. Its three-cell battery provides 8.5 hours of power - giving you more than enough time to get those essential daily tasks done.
This Chromebook laptop weighs only 1.4kg, so it's lightweight enough to carry around with you when you're commuting. It also features the latest 802.11ac2 wireless technology, providing connection speeds as much as three times faster than previous Wi-Fi technologies.
What's more, the Chromebook 11 starts up rapidly - so it'll be up and running in as little as seven seconds.
  • Always better
    Start in seconds and have that computer feeling - every time. Chromebook's cloud-based Chrome OS and built-in virus protection refresh on reboot. No updates to track, no discs to insert, and backups are automatic, too. Unlike other computers, Chromebooks get better with age. Plus, Chrome OS's intuitive interface makes it all so simple.
  • Always HD
    The Acer C7 Chromebook's 11.6 HD screen energizes your videos, pictures and web content. Crisp resolution brings family closer during video chats, and the HD webcam presents you at your best, too. Images are crystal clear on HD devices like monitors, projectors and TVs via the HDMI port, and connect as you please.
  • Always simple
    Chromebooks require almost no setup, so you can go from unboxing to doing in minutes. Tasks are easy using the extra-large, button-free touchpad. Stay online with the Acer C7 Chromebook's convenient and reliable wireless.
Acer Chromebook 11 C730-C10K - 11.6" - Intel Celeron - N2840 - 4 GB RAM - 32 GB SSD - UK
Chromebook
Operating System
Chrome OS
Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
32 GB SSD
Display
11.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics
Keyboard
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell
Grey
30.26 cm x 20.66 cm x 2.175 cm
1.4 kg
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.58 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
32 GB SSD
Display
11.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - HD
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
3-cell
3220 mAh
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
HDMI , Headphone/microphone combo jack , 2 x USB 2.0
Memory Card Reader
Yes (SD Card)
Grey
Power adapter
1.4 kg
