Thin, light and equipped with an array of premium features, the Acer Chromebook 11 combines power and practicality - as well as value for money.
Acer's 11.6-inch Chromebook provides a number of improvements on its predecessor. Its design is tougher and more robust, with a thicker cover, reinforced corners, longer hinge brackets and additional rib panels. Its spill-resistant keyboard is also complemented by a liquid drainage system to provide protection against accidents.
Powered by a 2.16GHz dual-core Intel Celeron processor, the Acer Chromebook 11 also comes equipped with 4GB RAM and a 32GB SSD hard drive. Its three-cell battery provides 8.5 hours of power - giving you more than enough time to get those essential daily tasks done.
This Chromebook laptop weighs only 1.4kg, so it's lightweight enough to carry around with you when you're commuting. It also features the latest 802.11ac2 wireless technology, providing connection speeds as much as three times faster than previous Wi-Fi technologies.
What's more, the Chromebook 11 starts up rapidly - so it'll be up and running in as little as seven seconds.
Always better
Start in seconds and have that computer feeling - every time. Chromebook's cloud-based Chrome OS and built-in virus protection refresh on reboot. No updates to track, no discs to insert, and backups are automatic, too. Unlike other computers, Chromebooks get better with age. Plus, Chrome OS's intuitive interface makes it all so simple. -
Always HD
The Acer C7 Chromebook's 11.6 HD screen energizes your videos, pictures and web content. Crisp resolution brings family closer during video chats, and the HD webcam presents you at your best, too. Images are crystal clear on HD devices like monitors, projectors and TVs via the HDMI port, and connect as you please. -
Always simple
Chromebooks require almost no setup, so you can go from unboxing to doing in minutes. Tasks are easy using the extra-large, button-free touchpad. Stay online with the Acer C7 Chromebook's convenient and reliable wireless.
- Acer Chromebook 11 C730-C10K - 11.6" - Intel Celeron - N2840 - 4 GB RAM - 32 GB SSD - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB SSD
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 3-cell
- Grey
- 30.26 cm x 20.66 cm x 2.175 cm
- 1.4 kg
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.58 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB SSD
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - HD
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Technology
- 3-cell
- Capacity
- 3220 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , 2 x USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Grey
- Included Accessories
- Power adapter
- 1.4 kg
