Chromebook for education customers, the Acer Chromebook 11 N7 provides enhanced durability features. In addition, it provides long battery life and a fan-less design, making it an exceptional choice for schools and school districts that want a reliable, powerful and quiet device for student learning.
Durable design features enhance real-time learning
The durability and design features of the Chromebook 11 N7 ensure maximum uptime and contribute to reduced IT maintenance. The Acer Chromebook 11 N7 has a spill-resistant keyboard. The unique gutter system under the keyboard and touchpad drains water so that it's routed away from internal components and out the bottom of the chassis. It also has a fan-less design that provides cool and quiet operation, so it doesn't add noise, even to a whole classroom of students. Also, reliability is boosted since it doesn't require venting that may cause airflow issues and dust accumulation. -
Long battery life
Administrators and teachers won't have to worry about charging their Acer Chromebook 11 N7 every evening, since it provides many hours of battery life. This long battery life is also ideal for 1:1 programs where students use their Chromebook throughout the school day, then take it home for homework and fun. -
Students stay connected
Students can stay connected to their campus network with the fast dual-band 2x2 MIMO 802.11ac Wi-Fi. The device connects easily to peripherals via Bluetooth 4.0, USB 3.0 ports and HDMI port. Students can plug in headphones with the 3.5 mm combo audio port. Files can be transferred with the device's built-in SD card reader.
- Acer Chromebook 11 N7 C731T-C96J - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 400
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell - up to 11 hours
- Grey
- 29.7 cm x 21 cm x 2.2 cm
- 1.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Glare, CineCrystal
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Technology
- 3-cell Lithium Ion
- Capacity
- 3980 mAh
- Run Time
- Up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , Headphone/microphone combo jack , 2 x USB 3.0
- Memory Card Reader
- 2 in 1 (SD Card, SDXC Card)
- Grey
- Case Material
- Polycarbonate ABS
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- MIL-STD 810G
- Localization
- 1.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
