With a powerful processor apps load faster, graphics run faster and many tasks can be run simultaneously without lag. This makes it ideal for heavy processing tasks like big spreadsheets and video transcoding.
Stylish yet tough
Strength, durability and stylish good looks are provided through the aluminum chassis and narrow bezel. The lightweight material means that it is less likely to be bent, warped or dented than other materials. -
Stay in touch
Keeping in touch with colleagues is easier with an HDR webcam. So that more than one person doesn't need to crowd around a tiny camera, the wide 75° lens will capture the entire room when you're keeping in touch. -
Stay productive
Fast boot times, ease of use, tough security and a long battery life are some of the advantages of the Acer Chromebook 714. With a fast boot time you'll start working quicker. -
Tougher, smoother touch
Tapping, swiping, scrolling and zooming are smoother than ever. The glass touchpad provides a slicker feel than a regular plastic touchpad, and gives users the confidence that they are purchasing durable, quality Chromebook.
- Acer Chromebook 714 CB714-1WT-5214 - 14" - Core i5 8250U - 8 GB RAM - 128 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB - eMMC
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 10 hours
- Security
- Fingerprint reader
- Steel grey
- 32.3 cm x 23.86 cm x 1.77 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
Storage
- Main Storage
- 128 GB SSD - (eMMC) - SanDisk
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Bezel Type
- Raised
- Anti-glare, ComfyView, 25 ms response rate, Narrow Border Display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, two microphones
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 2230
- Technology
- 4-cell Lithium Ion
- Capacity
- 56 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
- 2 x USB-C 3.1/DisplayPort/HDMI , USB 3.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDXC)
- Steel grey
- Security
- MIMO technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- MIL-STD 810G
- Localization
- 1.6 kg
