Acer Chromebook 714 Intel Core i5-8250U 8GB 128GB 14"
Quicklinx: G0GCWS00 Mfr#: NX.HAWEK.004
  • Core i5
  • IEEE 802.11n
With a powerful processor apps load faster, graphics run faster and many tasks can be run simultaneously without lag. This makes it ideal for heavy processing tasks like big spreadsheets and video transcoding.
  • Hidden Power
    With an 8th Gen Intel Core i processor, apps load faster, graphics run faster and many tasks can be run simultaneously without lag. This makes it ideal for heavy processing tasks like big spreadsheets and video transcoding.
  • Stylish Yet Tough
    Strength, durability and stylish good looks are provided through the 100% aluminium chassis and narrow 6.18-mm bezel. The lightweight material means that it is less likely to be bent, warped or dented than other materials. Coloured aluminium is anodised so there's no paint to chip and heat dissipation and corrosion resistance is improved.
  • Fingerprint Sensor
    A first for any Chromebook, an optional embedded fingerprint reader located next to the optional backlit keyboard is a quick and secure way for users to unlock and verify their identity without a password. Since the fingerprint's details are stored on the Chromebook itself, and not on the cloud, a user's fingerprints are kept safe.
  • Make Google Do It
    Ask questions, set reminders, play music, control your home and more through Google Assistant.This Acer Chromebook comes with dual-microphone voice processing designed to recognise verbal requests from anywhere in the room, even in noisy, real-world conditions.
  • Stay In Touch
    Keeping in touch with colleagues is easier with a wide Field-of-View HDR webcam and optional 10-point touch IPS screen. So that people don't need to crowd around a tiny camera, the wide 75° lens will capture the entire room when you're keeping in touch.
  • Stay Productive
    Fast boot times, ease of use, tough security and a long battery life are some of the advantages of Chrome OS. With a boot time of about 8 seconds you'll start working quicker; the simplified interface makes it easy to learn; integrated malware protection stops viruses in their tracks; and finally an efficient use of power means that you can work all day without your power adapter.
  • Tougher, Smoother Touch
    Tapping, swiping, scrolling and zooming are smoother than ever. The Corning Gorilla glass touchpad provides a slicker feel than a regular plastic touchpad, and gives users the confidence that they are purchasing a durable, quality Chromebook. With the ability to withstand scratches and dents, it will continue to look as slick as the day you bought it.
Acer Chromebook 714 CB714-1WT-5214 - 14" - Core i5 8250U - 8 GB RAM - 128 GB eMMC - UK
Chromebook
Operating System
Chrome OS
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
128 GB eMMC
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10 hours
Security
Fingerprint reader
Steel grey
32.3 cm x 23.86 cm x 1.77 cm
1.6 kg
Region: United Kingdom
Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
Storage
Main Storage
128 GB eMMC - SanDisk
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare, ComfyView, 25 ms response rate, Narrow Border Display
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, two microphones
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 2230
4-cell Lithium Ion
56 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
2 x USB-C 3.1 (supports DisplayPort, HDMI) , USB 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDXC)
Steel grey
Security
Fingerprint reader
MIMO technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
MIL-STD 810G
Localization
1.6 kg
