Acer Chromebase CA24I CM3215U 4GB 16GB SSD No ODD UMA Chrome
Quicklinx: CGD7WS00 Mfr#: DQ.Z0DEK.001
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
The Acer Chromebase 24 (CA24I) features a 23.8-inch Full HD (1920 x 1080) display with IPS technology, reproducing consistent and accurate colors at up to 178-degree wide viewing angles. VESA mount support allows for even more convenient operation, making it an easy fit in any public space such as for use as digital signage or kiosk device. Powerful processors provide the Chromebase 24 with outstanding performance. Optimized for video conferencing, the Chromebase 24 incorporates four digital microphones, and can capture the perfect frame with the chassis that easily tilts from - 5° to 30° in addition to the adjustable HD webcam.
Acer Chromebase CA24I_Wtb3215U - all-in-one - Celeron 3215U 1.7 GHz - 4 GB - SSD 16 GB - LED 23.8"
Chromebox - all-in-one
Region: United Kingdom
1 x Intel Celeron 3215U / 1.7 GHz (Dual-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM
Hard Drive
SSD 16 GB - SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
Monitor
23.8" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics
Camera
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
Google Chrome OS
58.28 cm x 3.6 cm x 40.12 cm
8 kg
Chromebox
Product Form Factor
All-in-one
Processor / Chipset
CPU
Intel Celeron 3215U
Clock Speed
1.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 8 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Configuration Features
2 x 2 GB
Hard Drive
SSD
1 x 16 GB
Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
Card reader
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
23.8"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Response Time
14 ms
Image Brightness
250 cd/m²
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Intel HD Graphics
Audio Output
Speakers Included
2 x right / left channel
Camera
Camera
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Audio Input
Four microphones
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Slots
SO-DIMM 204-pin
1 x LAN - RJ-45
Wireless antenna
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Google Chrome OS
58.28 cm
3.6 cm
40.12 cm
8 kg
