Acer CB351Cbmidphzx 35" 2560x1080 4ms HDMI DVI DP USB 3.0 Monitor
Quicklinx: CP8YWS00 Mfr#: UM.CB1EE.001
Acer CB351C - LED monitor - 35"
LED-backlit LCD monitor - 35"
Energy Class
Class B
Energy Consumption per Year
72 kWh
Power Consumption (On mode)
49 W
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 120/230 V
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
72 kWh
Diagonal Size
35"
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, ComfyView, Flicker-Less technology, sRGB Colour Correction technology, Blue Light Filter technology, Super Sharpness technology, EyeProtect
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI-D (dual link) , 2 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+25
Swivel Angle
120
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable
Input Voltage
AC 120/230 V
49 W
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
