Acer CB281HKbmjdprx 28" 3840x2160 1ms HDMI DVI DP Monitor
Quicklinx: CP93WS00 Mfr#: UM.PB1EE.001
The Acer CB Series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
  • Prosumer
  • Seamless visuals
    Wide viewing angles on the CB Series preserve image clarity for better views all around. Their wide color gamut presents more colors on the screen. Flicker-less technology combined with a 1 ms response time removes screen flicker and renders images faster. What's more, Acer ComfyView technology reduces reflections to provide more comfort for your eyes.
  • Enhanced usability
    These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort. You can seamlessly expand your view across multiple monitors thanks to a Zero Frame design, or see more on the same screen with picture-in-picture and picture-by-picture technologies.
Acer CB281HK - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
75 kWh
Power Consumption (On mode)
51 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI/MHL: 60 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
DVI-D, DisplayPort, HDMI (MHL)
Display Position Adjustments
Height, pivot (rotation)
Voltage
AC 100 - 240 V
3-year warranty
Display Type
Energy Class
Class C
75 kWh
Diagonal Size
28"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM)
Audio
Speakers
DVI-D (dual link) (HDCP) , MHL / HDMI , DisplayPort , Audio line-out
Mechanical
1 x DVI cable , 1 x DisplayPort cable
Input Voltage
AC 100 - 240 V
51 W
On / Off Switch
Limited warranty - 3 years
