CB1 Series monitors are designed for a great visual experience. With vivid high-resolution, clarity and comfort, they produce sharp images and true-to-life colour. The also come packed with features to enhance the visual experience while providing added comfort and protection.
Visually outstanding
CB1 series monitors combine multiple features and technologies to produce a superior visual experience. With high resolutions, wide viewing angles and added color and clarity enhancement technologies, it's a beautiful view. -
Protective comfort
CB1 displays are a bonanza of features that both improve your viewing experience and help reduce eye strain. The flicker-less display has blue light filter and glare reduction features that significantly improve viewing comfort while enhancing eye protection. -
Usability enhancements
All CB1 monitors have enhanced ergonomics thanks to the clever design of their supporting ErgoStand, which enables a wide range of tilt, swivel and height adjustments. With the ErgoStand, you can adjust the display to practically any position and purpose.
- Acer CB271H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 60 kWh
- Power Consumption (On mode)
- 41 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Black
- 64 cm x 23.7 cm x 55.2 cm
- 7.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Part 15, WEEE, Directive 1275/2008, Directive 2009/125/EC, EN 50564:2011, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, IEC 62301:2011, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 60 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 1 ms
- Backlight Technology
- LED backlight
- ErgoStand, picture by picture, frameless, Zero Frame, 6-axis colour adjustment
- Black
- 64 cm x 23.7 cm x 55.2 cm - with stand
- 7.33 kg
Audio
- Speakers
- VGA , DVI , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 60
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Acer Eyeprotect technology
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- 41 W
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.4 kg , With stand - width: 64 cm - depth: 23.7 cm - height: 55.2 cm - weight: 7.33 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
