Acer CB270HU 27" 2650x1440 6ms DVI HDMI DP IPS LED Monitor
Quicklinx: 9L9CWS00 Mfr#: UM.HB0EE.001
The Acer Prosumer series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
  • Great details
    This monitor provides stunning image quality and sharp details with UHD, WQHD and FHD high resolution. This monitor also has color adjustment to meet the highest standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker.
  • Seamless visuals
    Wide viewing angles preserve image clarity for better views all around. Their wide color gamut presents more colors on the screen. Flicker-less technology combined with a quick response time removes screen flicker and renders images faster. What's more, Acer ComfyView technology reduces reflections to provide more comfort for your eyes.
  • Enhanced usability
    These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ErgoStand that allows you to adjust the viewing angle for maximum comfort. You can seamlessly expand your view across multiple monitors thanks to a Zero Frame design, or see more on the same screen with picture-in-picture and picture-by-picture technologies.
  • Eco-friendly
    This monitor is RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. This monitor meets several international standards for green technology.
Acer CB270HU - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DVI, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
AC 120/230 V
Black glossy with silver ring on footstand
63.97 cm x 24.47 cm x 55.81 cm
7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV, GS, ISO9241-307
3-year warranty
Display Type
Energy Class
Class B
61 kWh
Diagonal Size
27"
Daisy Chaining
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
108.8
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
6 ms
Vertical Refresh Rate
23 - 76 Hz
Horizontal Refresh Rate
15 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ErgoStand, Acer EcoDisplay, ComfyView, Hard Coating (3H)
7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x DVI cable
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
AC 120/230 V
Power Consumption (Typical)
28.4 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
400 mW
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 24.47 cm - height: 55.81 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
9L9C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
