Product
Acer CB241HYbmdr 23.8" 1920x1080 4ms VGA DVI Monitor
Quicklinx: CP99WS00 Mfr#: UM.QB1EE.009
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£156.99 ex VAT
£188.38 inc VAT
This monitors provide stunning image quality and sharp details. They also have color adjustment to meet high color accuracy. With the clear view provided by these monitors, you can work clearer and get the job done quicker.
  • Seamless visuals
    The CB series delivers better views all around. Their wide color gamut presents more colors on the screen. Flicker-less technology removes screen flicker and renders images faster. What's more, Acer ComfyView technology reduces reflections to provide more comfort for your eyes.
  • Enhanced usability
    These monitors automatically adjust the screen brightness. A multi-function ErgoStand allows you to adjust the viewing angle for maximum comfort.
Acer CB241HY - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Screen Coating
Anti-glare
54.1 cm x 21.7 cm x 37.6 cm
5.9 kg
United Kingdom, Europe, EMEA
TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, anti-glare, Acer Adaptive Contrast Management (ACM), Zero Frame
5.9 kg
Audio
Speakers
Output Power / Channel
2 Watt
VGA , DVI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
1 x VGA cable , 1 x DVI cable
TCO Displays 6.0
20.8 Watt
Power Consumption Sleep
480 mW
Power Consumption (Off Mode)
380 mW
Limited warranty - 3 years - carry-in
5 °C
35 °C
10 - 85%
Acer CB241HYbmdr 23.8 Bundle deal on Acer CB241HYbmdr 23.8" 1920x1080 4ms VGA DVI Monitor
£252.00
Response Time: 4ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
