Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI HDMI MM H
Quicklinx: C4PKWS00 Mfr#: UM.FB6EE.045
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£126.73 ex VAT
£152.07 inc VAT
The Acer CB series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus they are designed to save power and costs.
  • Great details
    These monitors provide stunning image quality and sharp details with high resolution. These monitors also have 6-axis color adjustment to meet high standard in color accuracy. With the clear view provided by these monitors, you can see work clearer and get jobs done quicker.
  • Seamless visuals
    Wide viewing angles on the CB series preserve image clarity for better views all around. Their wide color gamut presents more colors on the screen.
  • Enhanced usability
    These monitors are equipped with low dimming technology that automatically adjusts the screen and a multi-function ergo stand that allows you to adjust the viewing angle for maximum comfort.
  • Eco-friendly
    CB series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer technologies and LED backlighting.
Acer CB241H bmidr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Height, pivot (rotation)
TCO Displays 6.0
3-year warranty
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
24"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms
Backlight Technology
LED backlight
Anti-glare, Acer Adaptive Contrast Management (ACM)
Audio
Speakers
VGA , DVI , HDMI
Mechanical
1 x VGA cable , 1 x DVI cable
TCO Displays 6.0
48 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Limited warranty - 3 years
Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI HDMI MM H Bundle deal on Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI HDMI MM H
£218.27
C4PK C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.15
C4PK C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.54
C4PK C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.31
C4PK C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
C4PK C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.65
C4PK C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.91
C4PK C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.74
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
