Acer CB241HBMIDR 24'' FHD LED Monitor 1ms 250nits DVI HDMI MM H
Quicklinx: C4PKWS00 Mfr#: UM.FB6EE.045
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£125.88 ex VAT
£151.05 inc VAT
The Acer CB series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus they are designed to save power and costs.
  • Full HD
    1920x1080 resolution in a 16:9 aspect ratio makes movies more real and dramatic. Small details and text are clear.
  • 1 ms response time
    This display's short response time eliminates ghosting, for crisp and perfectly rendered action sequences.
  • Acer eColor
    Easily adjust display settings to suit whatever you're viewing - data, media, movies or photos.
  • VESA mount
    Save space and add drama to the room by putting this display on the wall. VESA mounting makes it easy.
  • Flicker-less technology
    Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods.
  • 6-axis color tuning
    Set the hue and saturation of red, green, blue, magenta, yellow or cyan independently - for perfect calibration.
Acer CB241H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
56.7 cm x 21.66 cm x 37.93 cm
6 kg
VCCI, CCC, FCC, ISO 9241-307, DDC-2B/CI, EAC, TUV Rheinland, NOM-NYCE
3-year warranty
Display Type
Energy Class
Class B
48 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Backlight Technology
LED backlight
ErgoStand, Acer Adaptive Contrast Management (ACM), Zero Frame, Flicker-Less technology, EyeProtect, Picture-in-Picture, Picture-by-Picture, Acer ColorPlus technology
56.7 cm x 21.66 cm x 37.93 cm - with stand
6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Height Adjustment
150 mm
1 x VGA cable , 1 x DVI cable
33 W
22.9 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
Limited warranty - 3 years
5 °C
35 °C
10 - 85%
C4PK C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.32
C4PK C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.95
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
