The Acer CB series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus they are designed to save power and costs.
Full HD
1920x1080 resolution in a 16:9 aspect ratio makes movies more real and dramatic. Small details and text are clear. -
1 ms response time
This display's short response time eliminates ghosting, for crisp and perfectly rendered action sequences. -
Acer eColor
Easily adjust display settings to suit whatever you're viewing - data, media, movies or photos. -
VESA mount
Save space and add drama to the room by putting this display on the wall. VESA mounting makes it easy. -
Flicker-less technology
Reduces annoying screen flickering that can cause eye strain when viewing the monitor for long periods. -
6-axis color tuning
Set the hue and saturation of red, green, blue, magenta, yellow or cyan independently - for perfect calibration.
- Acer CB241H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 48 kWh
- Power Consumption (On mode)
- 33 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.7 cm x 21.66 cm x 37.93 cm
- 6 kg
- VCCI, CCC, FCC, ISO 9241-307, DDC-2B/CI, EAC, TUV Rheinland, NOM-NYCE
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 48 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Backlight Technology
- LED backlight
- ErgoStand, picture by picture, Acer Adaptive Contrast Management (ACM), Zero Frame, Flicker-Less technology, EyeProtect, Picture-in-Picture, Acer ColorPlus technology
- Black
- 56.7 cm x 21.66 cm x 37.93 cm - with stand
- 6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 120
- Height Adjustment
- 150 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Input Voltage
- 33 W
- Power Consumption (Typical)
- 22.9 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 10 - 85%
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £6.97 |
