The Acer Chromebase 24 (CA24I) features a 23.8-inch Full HD (1920 x 1080) display with IPS technology, reproducing consistent and accurate colors at up to 178-degree wide viewing angles. VESA mount support allows for even more convenient operation, making it an easy fit in any public space such as for use as digital signage or kiosk device. Powerful processors provide the Chromebase 24 with outstanding performance. Optimized for video conferencing, the Chromebase 24 incorporates four digital microphones, and can capture the perfect frame with the chassis that easily tilts from - 5° to 30° in addition to the adjustable HD webcam.
- Acer Chromebase CA24I_Wb3215U - all-in-one - Celeron 3215U 1.7 GHz - 4 GB - SSD 16 GB - LED 23.8"
- Chromebox - all-in-one
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Celeron 3215U / 1.7 GHz (Dual-Core)
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 8 GB (max) - DDR3L SDRAM
- Hard Drive
- SSD 16 GB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Card Reader
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Google Chrome OS
- 58.28 cm x 3.6 cm x 40.12 cm
- 8 kg
- Chromebox
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Intel Celeron 3215U
- Clock Speed
- 1.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 8 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Configuration Features
- 2 x 2 GB
Hard Drive
- SSD
- Capacity
- 1 x 16 GB
- Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- Card reader
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Response Time
- 14 ms
- Image Brightness
- 250 cd/m²
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Intel HD Graphics
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Camera
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
Audio Input
- Four microphones
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- SO-DIMM 204-pin
- 1 x LAN - RJ-45 , 1 x HDMI , 3 x USB 3.0 , 1 x USB 2.0 , Audio line-out
- Included Accessories
- Wireless antenna
- RoHS
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Google Chrome OS
- 58.28 cm
- 3.6 cm
- 40.12 cm
- 8 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
