Some of your best ideas happen outside the boardroom - and now you can share them when they happen with Acer Travel Series projectors. Discuss concepts and motivate others, even without a PC, wherever you go. With models as slim as 1" (24.5 mm), the world of self-expression is in your pocket.
Ideas in your pocket
Some of your best ideas happen outside the boardroom - and now you can share them when they happen with Acer Travel series projectors. Discuss concepts and motivate others, even without a PC, wherever you go. With models as slim as 1" (24.5 mm), the world of self-expression is in your pocket. -
Easy to bring
Project your concepts anywhere, anytime. However long or deep your presentations, they can fit in a pocket - or your palm. Be PC-free: Access your files straight from a USB drive or SD card or even a smartphone. Explore your thoughts in detail by connecting via an HDMI port to high-definition sources. -
Crisp and radiant
Text is crisp and graphics are clear even from far away thanks to fine contrast ratios. Your ideas will pop with the high brightness of LED technology, creating vibrant visuals and delivering consistent color saturation. With Acer ColorSafe technology, those colors retain their natural look even after prolonged projector use. -
Ultra practical
Get right to your point: Select models immediately detect signals from multiple sources, are compatible with preferred presentation software, and offer multi-format support. User interfaces are intuitive so you can concentrate on your thoughts, not your actions, and the quality of your presentations is enhanced with an integrated speaker. -
Earth kind
Let your ideas and the planet both blossom. The extended lifespan of LED lamps saves replacement costs and ensures long projector use, as does eco mode. The absence of hazardous mercury or halogen gases means safer use, and a fan-less design cuts costs while maintaining a quiet that keeps attention on you.
- Acer C205 - DLP projector
- DLP projector
- Built-in Devices
- Battery
- Brightness
- 150 lumens
- Contrast Ratio
- 1000:1
- Resolution
- WVGA (854 x 480)
- Native Aspect Ratio
- 16:9
- Colour Support
- 16.7 million colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 14.4 cm x 10.8 cm x 2.7 cm
- 302 g
- 2-year warranty
- DLP projector
- Built-in Devices
- Battery
Projector
- Brightness
- 150 lumens
- Contrast Ratio
- 1000:1
- Image Size
- 38.1 cm - 254 cm
- Projection Distance
- 0.6 m
- Resolution
- WVGA - WVGA (854 x 480) (native) / 1280 x 800 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 60 Hz x 50 kHz
- Bulb type
- Laser/LED
- Bulb life cycle
- 16:9 aspect ratio support, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7
Video Input
- Video Interfaces
- HDMI, USB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- 1 x USB - 4 pin USB Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm
- Included Accessories
- Carrying case
- Cables Included
- 1 x Mobile High-Definition Link (MHL) cable
- Voltage Required
- AC 120/230 V
- 14.4 cm
- 10.8 cm
- 2.7 cm
- 302 g
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
