Acer C205 FWVGA DLP 150 Lumens Ultra Portable Projector
Quicklinx: 9JQ9WS00 Mfr#: MR.JH911.001
Some of your best ideas happen outside the boardroom - and now you can share them when they happen with Acer Travel Series projectors. Discuss concepts and motivate others, even without a PC, wherever you go. With models as slim as 1" (24.5 mm), the world of self-expression is in your pocket.
  • Ideas in your pocket
    Some of your best ideas happen outside the boardroom - and now you can share them when they happen with Acer Travel series projectors. Discuss concepts and motivate others, even without a PC, wherever you go. With models as slim as 1" (24.5 mm), the world of self-expression is in your pocket.
  • Easy to bring
    Project your concepts anywhere, anytime. However long or deep your presentations, they can fit in a pocket - or your palm. Be PC-free: Access your files straight from a USB drive or SD card or even a smartphone. Explore your thoughts in detail by connecting via an HDMI port to high-definition sources.
  • Crisp and radiant
    Text is crisp and graphics are clear even from far away thanks to fine contrast ratios. Your ideas will pop with the high brightness of LED technology, creating vibrant visuals and delivering consistent color saturation. With Acer ColorSafe technology, those colors retain their natural look even after prolonged projector use.
  • Ultra practical
    Get right to your point: Select models immediately detect signals from multiple sources, are compatible with preferred presentation software, and offer multi-format support. User interfaces are intuitive so you can concentrate on your thoughts, not your actions, and the quality of your presentations is enhanced with an integrated speaker.
  • Earth kind
    Let your ideas and the planet both blossom. The extended lifespan of LED lamps saves replacement costs and ensures long projector use, as does eco mode. The absence of hazardous mercury or halogen gases means safer use, and a fan-less design cuts costs while maintaining a quiet that keeps attention on you.
Acer C205 - DLP projector
DLP projector
Built-in Devices
Brightness
150 lumens
Contrast Ratio
1000:1
Resolution
WVGA (854 x 480)
Native Aspect Ratio
16:9
Colour Support
16.7 million colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Speakers
Speaker(s) - integrated
AC 120/230 V
14.4 cm x 10.8 cm x 2.7 cm
302 g
DLP projector
Built-in Devices
Projector
Brightness
150 lumens
Contrast Ratio
1000:1
Image Size
38.1 cm - 254 cm
Projection Distance
0.6 m
Resolution
WVGA - WVGA (854 x 480) (native) / 1280 x 800 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
60 Hz x 50 kHz
Bulb type
Laser/LED
Bulb life cycle
16:9 aspect ratio support, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.7
Video Input
Video Interfaces
HDMI, USB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
2 Watt
1 x USB - 4 pin USB Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm
Carrying case
1 x Mobile High-Definition Link (MHL) cable
AC 120/230 V
14.4 cm
10.8 cm
2.7 cm
302 g
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
9JQ9 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
