Acer C120 - DLP projector
Quicklinx: 8CZ3WS00 Mfr#: EY.JE001.002
Hurry, only 1 left in stock!
£192.98 ex VAT
£231.57 inc VAT
The ultra-lightweight Acer C series LED pico projector fits easily in your pocket. Carry it along with an external device and you can present anywhere, even without a PC. Sufficient battery life beams your videos, photos and on-the-spot business presentations in various formats.
  • Lively display
    The incredibly light C series projector boasts exceptional resolution and stunning brightness along with very high contrast ratio to deliver crystal-clear visuals. And, with Acer ColorSafe technology, the color integrity of your images is preserved even after prolonged use of the projector.
  • Convenient and flexible on the go
    This compact and light palm-sized projector is very easy to set up. Enjoy direct access of files stored in your external device - no need for a PC or video player! You can also connect to high-definition sources using the mini HDMI port.
  • Dynamic usability
    Your presentation will be smart and simple via this projector's immediate detection of input signals and complete multi-format support. In addition, a built-in speaker provides quality audio for enhanced presentations and entertainment.
  • Eco-friendly functionality
    The Acer C series features eco-conscious technologies: long LED lamp life saves lamp replacement costs and ensures long-lasting projector use; a power-saving mode extends the lifespan of the LED lamp and reduces power consumption; and this projector's fan-less design saves cost while delivering quiet enjoyment.
DLP projector
Brightness
100 lumens
Contrast Ratio
1000:1
Resolution
WVGA (854 x 480)
Native Aspect Ratio
16:9
Colour Support
16.7 million colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
AC 120/230 V
20 Watt
12 cm x 8.2 cm x 2.6 cm
180 g
DLP projector
Projector
Brightness
100 lumens
Brightness (Reduced)
75 lumens
Contrast Ratio
1000:1
Image Size
25 cm - 254 cm
Projection Distance
0.4 m - 3.7 m
Throw Ratio
1.65:1
Resolution
WVGA - WVGA (854 x 480)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
60 Hz x 32.2 kHz
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
USB powered, SmartFormat Technology
Lens
Focus Type
Manual
Lens Aperture
F/1.87
1 x USB 3.0
Carrying case
1 x USB cable
Nominal Voltage
AC 120/230 V
20 Watt
Power Consumption Operational (Standby)
0.5 Watt
12 cm
8.2 cm
2.6 cm
180 g
5 °C
20 - 90% (non-condensing)
Sound Emission
30 dBA
24 dBA
8CZ3 C2G 2m USB 3.0 A Male to Micro B Male Cable In Stock £5.82
8CZ3 C2G USB 3.0 to Gigabit Ethernet Network Adapter In Stock £23.54
