Acer BE270UA 27" 2560x1440 6ms HDMI DisplayPort USB-C 3.1 IPS LED Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: CXF9WS00 Mfr#: UM.HB0EE.A08
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
£274.06 ex VAT
£328.87 inc VAT
Acer's BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb color definition, EyeProtect technologies, and a 4-side borderless zeroframe design so you can work comfortably all day.
Acer BE270U - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
30 W
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 75 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
6.25 kg
Environmental Standards
ENERGY STAR Qualified
Directive 1275/2008, EN 50564:2011, EN55022:2010/AC:2011 Class B, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN 61000-3-3:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN55024:2010
Display Type
Energy Class
Class A
43 kWh
30 W
Diagonal Size
27"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
100% sRGB colour gamut
6.25 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DisplayPort , Audio line-out , 4 x USB 3.1 downstream , USB 3.1 upstream , USB-C
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x USB-C cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
490 mW
Power Consumption (Off Mode)
450 mW
ENERGY STAR Certified
Acer BE270UA 27 Bundle deal on Acer BE270UA 27" 2560x1440 6ms HDMI DisplayPort USB-C 3.1 IPS LED Monitor
£373.23
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Acer
Price Range Ex VAT: 150 - 300
