Acer BE270U 27" 2560x1440 6ms HDMI MHL DisplayPort USB IPS LED Monitor
Quicklinx: CXFCWS00 Mfr#: UM.HB0EE.013
Acer's BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb color definition, EyeProtect technologies, and a 4-side borderless zeroframe design so you can work comfortably all day.
  • Perform at your best
    Work in finer detail with ultra-high resolution screens that give you plenty of working space with exceptional viewing angles. 1 What's more, if you place monitors next to each other, the zeroframe design ensures an almost uninterrupted view.
  • True-to-life colors
    Make sure your final product looks as good in real life as it did on the screen through tweaking settings in Acer ColorPlus technology and 6-axis color adjustment. 100% sRGB color coverage means you can really trust your monitor's color reproduction.
  • Eye-friendly brilliance
    Acer EyeProtect technology helps to reduce eyestrain by eliminating screen flicker and blue light emissions. Meanwhile, Low dimming technology automatically adjusts screen brightness according to ambient light conditions.
  • Eco-responsible productivity
    Acer BE0 monitors boast a wide spectrum of certifications, including ENERGY STAR, TCO 7.0 and EPEAT Gold so you can rest assured that your productivity is also eco-responsible.
Acer BE270U - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 75 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
6.25 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Directive 1275/2008, EN 50564:2011, EN55022:2010/AC:2011 Class B, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN 61000-3-3:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN55024:2010
3-year warranty
Display Type
Energy Class
Class A
43 kWh
30 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
100% sRGB colour gamut
6.25 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x SuperSpeed USB-C cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
490 mW
Power Consumption (Off Mode)
450 mW
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
