Acer BE240Y 23.8" 1920x1080 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: CXFDWS00 Mfr#: UM.QB0EE.006
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
£190.68 ex VAT
£228.81 inc VAT
Acer’s BE0 monitors offer a class-leading combination of ultra-high resolution screens, superb colour definition, EyeProtect technologies and a 4-side borderless zeroframe design so you can work comfortably all day.
Acer BE240Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
16.85 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
6.25 kg
Directive 1275/2008, EN 50564:2011, EN55024:2010, EN61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, IEC 62301:2011, EN55022:2010 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, TCO Displays 7.0
Display Type
Energy Class
Class A+
26 kWh
16.85 W
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
100% sRGB colour gamut
6.25 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
18 Watt
Power Consumption Stand by
490 mW
Power Consumption (Off Mode)
450 mW
Acer BE240Y 23.8 Bundle deal on Acer BE240Y 23.8" 1920x1080 6ms HDMI DisplayPort USB IPS LED Monitor
£289.85
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Acer
Price Range Ex VAT: 150 - 300
