Acer B6 Series B246HL 24" 1920 x 1080 Full HD 5ms VGA DVI LED Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: 8NTKWS00 Mfr#: UM.FB6EE.009
The Acer B series is designed for professionals who require exceptional visuals and comfortable viewing over long periods of time. Its ergonomic style, high contrast ratio, full digital connectivity, and dependable functionality make the B series an outstanding tool for productive computing.
  • Professional, ergonomic style
    The Acer B series monitor comes in a stylish bezel, complemented by an elegant, sturdy base, along with control buttons on the front panel to allow easy cleaning and intuitive use. To ensure comfort during prolonged use, you can adjust the height and tilt for the best viewing position. The spacious widescreen is great for multitasking with several open windows.
  • High-performance display
    Acer exclusive technologies, together with the excellent resolution, fast response time and high contrast ratio ensure reliable use and solid performance.
  • Vital connections
    Connect to the digital displays and appreciate media without loss of quality via the DVI port with High-bandwidth Digital Content Protection (HDCP) support.
Acer B246HLymdr - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Dark grey
56.7 cm x 22.12 cm x 38.55 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
TUV GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Zero Bright Dot, HDCP
Dark grey
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI (HDCP)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable
Security Slot Type
Kensington security slot
Power Supply
Internal
AC 120/230 V
20.9 Watt
Power Consumption Stand by
0.55 Watt
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
8NTK C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.09
8NTK C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.32
