Acer B346CKbmijphzx 34" 3440x1440 HDMI DP USB Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: CPF0WS00 Mfr#: UM.CB6EE.018
The ultra-wide screens and picture-by-picture capability make it possible to view large spreadsheets, brochures, newsletters and two documents side by side. Picture-in-picture capability enables customers to watch a movie in a box on the screen, while working on a project. Thanks to an IPS panel, wide 178-degree viewing angles enhance visual collaboration with others on joint projects.
The display meet the highest standards for color accuracy with 100 percent sRGB coverage and 6-axis color adjustment. Both displays have a 21:9 aspect ratio, while the Acer B346CK delivers 3202 cd/m brightness and 1.07 billion colors. A crisp 100,000,000:1 maximum contrast ratio and a 6 ms response time contribute to the stunning picture quality. Acer ComfyView non-glare protection provides clearer, more comfortable viewing via a polarizer material to reduce reflections.
VESA compliant, the displays can be mounted on a wall to save valuable desk space and two 3 W speakers provide quality audio. Optimized for maximum comfort, a multi-function ErgoStand provides tilt adjustable 25 degrees up or -5 degrees down, swivel 60 degrees to the right or left, and height up to 5.9 inches up or down. Connectivity options feature HDMI with MHL for charging portable devices, DisplayPort and a USB 3.0 hub for connecting multiple peripherals simultaneously.
In addition to being ENERGY STAR and TCO 6.0 qualified, the Acer B346CK is EPEAT Gold registered, the highest level of EPEAT registration available. Mercury-free and LED-backlit, these monitors reduce energy costs by consuming less power than standard CCFL-backlit displays and are safer for the environment.
Acer B346CKbmijphzx - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Power Consumption (On mode)
61 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440 at 60 Hz
Brightness
320 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, HDMI (MHL)
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
82.8 cm x 26.67 cm x 58.93 cm
9.98 kg
Environmental Standards
TCO Certified Displays 7
RoHS
3-year warranty
Display Type
Energy Class
Class C
88 kWh
61 W
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Brightness
320 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView
82.8 cm x 26.67 cm x 58.93 cm - with stand
9.98 kg
Audio
Speakers - stereo
MHL / HDMI , HDMI , DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+25
Swivel Angle
60
Height Adjustment
150 mm
VESA interface support
1 x DisplayPort cable , 1 x SuperSpeed USB cable
RoHS
53.5 Watt
Power Consumption Stand by
500 mW
TCO Certified
Limited warranty - 3 years - carry-in
