Acer B326HUL 32" 2560x1080 6ms DVI HDMI USB LED Monitor
Quicklinx: 9L9MWS00 Mfr#: UM.JB6EE.001
The Acer B3 series is designed for professionals who require exceptional visuals and comfortable viewing over long periods of time. Its robust ergonomic design, high contrast ratio, full digital connectivity, premium LED technology, and dependable functionality make the B3 series an outstanding tool for productive computing.
Acer B326HUL - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
74 kWh
Power Consumption (On mode)
51 W
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Dark grey
United Kingdom, Europe, EMEA
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Energy Class
Class B
74 kWh
51 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Dark grey
Audio
Speakers
DVI , HDMI , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
VESA Mounting Interface
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
On / Off Switch
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
9L9M C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9L9M C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.42
9L9M C2G 5m Select High Speed HDMI with Ethernet In Stock £21.40
