Acer B326HK 32" 3840x2160 6ms DVI HDMI 4K IPS Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: BQSHWS00 Mfr#: UM.JB6EE.A02
Ideal for use in office environments, libraries and computer labs, B6 Series monitors deliver dynamic and energizing visuals thanks to their high display resolution and true-to-life colors. They also feature an ergonomic design for comfortable all-day computing, and they use eco-friendly technologies to save power and cut energy costs.
Acer B326HK - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
93 kWh
Power Consumption (On mode)
64 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Dark grey
73.79 cm x 26.65 cm x 62.34 cm
12 kg
Environmental Standards
TCO Certified Displays 8
Display Type
Energy Class
Class C
93 kWh
64 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
Dark grey
73.79 cm x 26.65 cm x 62.34 cm - with stand
12 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
MHL / HDMI , DVI , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
60
1 x DisplayPort cable , 1 x DVI cable , 1 x SuperSpeed USB cable
Power Supply
Internal
AC 120/230 V
44 Watt
Power Consumption Stand by
0.39 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 73.79 cm - depth: 6.2 cm - height: 45.36 cm - weight: 7.95 kg , With stand - width: 73.79 cm - depth: 26.65 cm - height: 62.34 cm - weight: 12 kg
TCO Certified
Limited warranty - 3 years
BQSH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQSH C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.29
BQSH C2G 5m Select High Speed HDMI with Ethernet In Stock £25.74
