Acer B286HK 28" 3840x2160 1ms DVI HDMI DisplayPort 4K LED Monitor
Quicklinx: 9T6LWS00 Mfr#: UM.PB6EE.009
The Acer B286HK is optimized for maximum comfort. Boasting a multi-function ErgoStand with tilt, swivel, pivot and height adjustment, the display can tilt 25 degrees up or -5 degrees down for finding the best view. It can also swivel 60 degrees to the right or left, while the height can be adjusted 5.9 inches up or down. VESA compliant, it can be mounted on a wall to free up desk space. The Acer B286HK display comes with Acer ComfyView non-glare protection that provides a polarizer material to reduce unnecessary lighting reflection for clearer, more comfortable viewing. A crisp high maximum contrast ratio provides excellent clarity, while the fast response time contributes to sharp images, critical for video. The display boasts wide viewing angles up to 170 degrees horizontal and up to 160 degrees vertical. It has a 16:9 aspect ratio, 300 cd/m brightness. Offering excellent connectivity, the Acer B286HK comes with HDMI with MHL for charging smartphones, tablets and other portable devices. It also provides DVI, DisplayPort, Mini DisplayPort and a USB 3.0 hub, so users can connect multiple peripherals simultaneously.
  • Sharp details
    Focus more clearly on your tasks thanks to the very high resolution of these monitors. The Ultra HD (4K2K) resolution delivers four times more pixels and detail than Full HD.
  • Comfortable computing
    Work comfortably for hours with Acer B6 Series monitors. These monitors deliver 100% sRGB coverage, for perfectly recreated colors. Acer ComfyView technology reduces glare, for greater eye comfort.
  • Flexible design
    Find a working angle that's perfect for you with the Acer ErgoStand, a stand that lets you easily adjust the screen's height, as well as letting you tilt and swivel it easily. Another great feature of the ErgoStand is that it allows you to effortlessly rotate the screen to portrait mode.
Acer B286HKymjdpprz - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
Dark grey
65.87 cm x 24.72 cm x 40.85 cm
EMEA
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class C
66 kWh
Diagonal Size
28"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
ErgoStand, HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
Dark grey
65.87 cm x 24.72 cm x 40.85 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI , HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
EMEA
Input Voltage
AC 120/230 V
45 W
Power Consumption (Typical)
39 Watt
Power Consumption Stand by
500 mW
On / Off Switch
Dimensions & Weight Details
With stand - width: 65.87 cm - depth: 24.72 cm - height: 40.85 cm , Without stand - width: 65.87 cm - depth: 6.45 cm - height: 38.19 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
9T6L C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
