Acer B277U 27" 2560x1440 4ms HDMI DP LED Monitor
Quicklinx: DYJMWS00 Mfr#: UM.HB7EE.011
The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
  • ZeroFrame design
    The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen.
  • Strong, ergonomic edge
    Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
  • Built-in speaker
    The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • Acer VisionCare
    Acer VisionCare incorporates several technologies to reduce eye strain and includes Acer Flickerless, BlueLightShield, Low Dimming and Acer ComfyView.
  • Wide range of color
    100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
  • Designed for accuracy
    Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
Acer B277U - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
32.1 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 75 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
61.4 cm x 20.75 cm x 54 cm
8.22 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Display Type
Energy Class
Class G
52 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Zero Frame, 6-axis colour adjustment, Adaptive-Sync technology, Acer VisionCare, Acer ColorPlus technology
61.4 cm x 20.75 cm x 54 cm - with stand
8.22 kg
Audio
Speakers - stereo
DisplayPort , HDMI
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
180
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
32.1 W
32.1 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.41 Watt
Power Consumption (Off Mode)
0.28 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 20.75 cm - height: 54 cm - weight: 8.22 kg , Without stand - width: 61.4 cm - depth: 6.57 cm - height: 38.6 cm - weight: 5.98 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
