Acer B277U 27" 2560 x 1440 4ms HDMI LED Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: F2R8WS00 Mfr#: UM.HB7EE.021
Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • Essential ergonomics
  • Infused with color
  • ZeroFrame design
  • Built-in speaker
Acer B277U bmiipprczx - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
USB 3.0 hub, FHD IR camera, microphone array
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-reflective, matte
Matte black
61.4 cm x 20.8 cm x 42 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
ISO 9241-307 Class 2
3-year warranty
Display Type
Energy Class
Class B
52 kWh
36 W
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
93
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 120 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
ErgoStand, High Frame Rate Control (Hi-FRC), ComfyView, 100% sRGB colour gamut, Flicker-Less technology, Low Dimming technology, 8-bit gamma, Acer VisionCare, Acer BluelightShield technology, 6-Axis Color Adjustments
Matte black
61.4 cm x 20.8 cm x 42 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Mini DisplayPort , DisplayPort (DisplayPort 1.2 mode) , 2 x HDMI , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
24 Watt
Power Consumption Stand by
0.41 Watt
Power Consumption (Off Mode)
0.28 Watt
On / Off Switch
Shipping Weight
11.26 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
