Acer B277 27" 1920x1080 4ms VGA HDMI DP LED Monitor
Quicklinx: D9ZPWS00 Mfr#: UM.HB7EE.005
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
10 in stock
£207.63 ex VAT
£249.15 inc VAT
The B7 Series display enhances your work professional needs with its strong, ergonomic stand and wide range of color-enhancing technologies.
  • Essential ergonomics
    Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for.
  • Infused with color
    In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision.
  • ZeroFrame design
    The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen.
  • A strong, ergonomic edge
    Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
  • Built-in speaker
    The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • A wide range of color
    100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
  • Designed for accuracy
    Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
Acer B277 bmiprzx - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
61.5 cm x 20.6 cm x 52.1 cm
10.2 kg
Austria, Germany
Environmental Standards
ENERGY STAR Qualified
3-year warranty
TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N; TravelMate X3 TMX3410-M-52M7; X5 TMX514-51-560Q, TMX514-51T-54EG
Display Type
Energy Class
Class A+
24 kWh
17 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology
61.5 cm x 20.6 cm x 52.1 cm - with stand
10.2 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
VGA , DisplayPort , HDMI , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+25
Height Adjustment
120 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Austria, Germany
Security Slot Type
Kensington security slot
AC 120/230 V (50 - 60 Hz)
17 Watt
Power Consumption Stand by
0.42 Watt
Power Consumption (Off Mode)
0.37 Watt
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.6 cm - height: 52.1 cm - weight: 10.2 kg , Without stand - width: 61.4 cm - depth: 6.6 cm - height: 36.7 cm - weight: 5 kg
ENERGY STAR Certified
Limited warranty - 3 years
Acer TravelMate P2410-G2-M-53RQ, P2510-G2-M-54J0, P614-51-50AA, P614-51TG-52A6, TMP614-51-588N , Acer TravelMate X3 TMX3410-M-52M7 , Acer TravelMate X5 TMX514-51-560Q, TMX514-51T-54EG
Acer B277 27 Bundle deal on Acer B277 27" 1920x1080 4ms VGA HDMI DP LED Monitor
£306.80
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
