Essential Ergonomics
Planted upon its sturdy and robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. -
Infused with Colour
In the professional world, accuracy is everything. Utilise colour-enhancing and eye care technologies for pinpoint precision -
ZeroFrame Design
The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. -
A Strong, Ergonomic Edge
Courtesy of a firm, stainless steel base, you can easily tilt, pivot, swivel and make height adjustments at a moment's notice. -
Built-in Speaker
The built-in speaker system lets you enjoy powerful sound without the need for a separate set up. -
Resolution Matters
Choose from a wide range of resolutions from Full HD up to 4K UHD. -
A Wide Range of Colour
100% sRGB means more colour and more accurate, lifelike images for the professional who demands perfection. -
Designed for Accuracy
Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colours and sharper overall visuals. -
Casually Make Adjustments
No need to fiddle with the buttons. Easily modify your monitor settings via our convenient Acer Display Widget utility software.
- Acer B227Q bmiprzx - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 17 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 49 cm x 19.3 cm x 37 cm
- 4.78 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 25 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ErgoStand, ComfyView, Zero Frame, Bluelight Filter, 72% NTSC colour gamut
- Black
- 49 cm x 19.3 cm x 37 cm - with stand
- 4.78 kg
Audio
- Speakers - stereo
- VGA , DisplayPort , HDMI , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable
- MTBF
- 30,000 hour(s)
- Security Slot Type
- Kensington security slot
- 17 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 13.5 Watt
- Power Consumption Stand by
- 0.27 Watt
- Power Consumption Sleep
- 0.39 Watt
- 0.27 Watt
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
