Product
Acer B277 21.5"  1920x1080 4ms VGA HDMI DP LED Monitor
Quicklinx: D9ZRWS00 Mfr#: UM.WB7EE.004
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£145.61 ex VAT
£174.73 inc VAT
Marketing description is not available.
  • Essential ergonomics
    Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for.
  • Infused with color
    In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision.
  • ZeroFrame design
    The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen.
  • A strong, ergonomic edge
    Courtesy of a firm, stainless steel base - you can easily tilt, pivot, swivel and make height adjustments at a moment's notice.
  • Built-in speaker
    The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • A wide range of color
    100% sRGB means more color, more accurate, lifelike images for the professional who demands perfection.
  • Designed for accuracy
    Acer ColorPlus is a set of technologies aimed to recreate realistic, consistent colors and sharper overall visuals.
Acer B227Q bmiprzx - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
49 cm x 19.3 cm x 37 cm
4.78 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 7.0
3 years warranty
Display Type
Energy Class
Class A
25 kWh
17 W
Diagonal Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, 72% NTSC colour gamut, ComfyView, Zero Frame, Bluelight Filter
49 cm x 19.3 cm x 37 cm - with stand
4.78 kg
Audio
Speakers - stereo
VGA , DisplayPort , HDMI , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable
MTBF
30.000 hour(s)
TCO Displays 7.0
Security Slot Type
Kensington security slot
13.5 Watt
Power Consumption Stand by
0.27 Watt
Power Consumption Sleep
0.39 Watt
Power Consumption (Off Mode)
0.27 Watt
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
20 - 80%
Acer B277 21.5 Bundle deal on Acer B277 21.5" 1920x1080 4ms VGA HDMI DP LED Monitor
£245.37
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
