Acer B276HULEymiipruzx 27" 2560x1440 6ms HDMI DP USB Monitor
Quicklinx: CP9JWS00 Mfr#: UM.HB6EE.E01
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 2 left in stock!
£331.63 ex VAT
£397.95 inc VAT
Ideal for use in office environments, libraries and computer labs, Professional series monitors deliver dynamic and energizing visuals. These monitors feature eco-friendly technologies that save power and cut energy costs. They are also ergonomically designed, with a slim and clean-cut look.
  • Flexible
    Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. These monitors are also wall-mountable, giving you clear views with more room.
  • Sharp
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitors. Plentiful built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, and more realistic colors.
  • Connective
    Collaborating with others is faster and more productive when you have ample ports available. Professional series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DVI, HDMI, USB 3.0 and DisplayPort.
  • Ecological
    Professional series monitors are RoHS compliant and mercury free. In addition, the advanced Acer EcoDisplay design plus white LED backlighting yield significant power savings. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer B276HUL - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, 2xDisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Dark grey
64 cm x 24.7 cm x 55.8 cm
8.51 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class C
66 kWh
Diagonal Size
27"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Mercury free, Acer eColor technology, 8-bit gamma
Dark grey
64 cm x 24.7 cm x 55.8 cm - with stand
8.51 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort , DisplayPort output , Audio line-in , 4 x USB 3.1 , USB-C
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Integrated cable management, portrait / landscape mode, VESA interface support, USB 3.0 port power off USB charging
1 x DisplayPort cable , 1 x USB-C cable
TCO Displays 6.0
AC 120/230 V
32.8 Watt
Power Consumption Stand by
490 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 64 cm - depth: 24.7 cm - height: 55.8 cm - weight: 8.51 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 6 kg
ENERGY STAR Certified
Acer B276HULEymiipruzx 27 Bundle deal on Acer B276HULEymiipruzx 27" 2560x1440 6ms HDMI DP USB Monitor
£430.80
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Acer
Price Range Ex VAT: 300 - 500
